31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Swept Blend for Basin
Fri, Oct 27, 2017 at 2:23:14 AM | Swept Blend for Basin
Tim79
Hi there,
I was hoping to use a swept blend to create a fairly simple basin form - using a quarter rotation from one profile to another, then mirroring to create the final element out of the 4 quarters.
The result is fairly bizarre! - see attached. Rather than a smooth oval form, I've ended up with a Rolling Stones style set of lips!
Any suggestions why the model is performing like this and how I can fix it? Or an alternative method.
Thanks very much for any help
T
Fri, Oct 27, 2017 at 5:00:54 AM | Swept Blend for Basin
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Couple of points.
Make sure your sketch path lines will transition from one quandrant to another correctly. i.e. does the line need to terminate perpendicular to the axial lines or does the angle it touches at the axial lines need to be adjusted ensure the profile sweeps smoothly through.
Also, make sure the location of the sketch profile and the sketch profile itself is correct to allow a smooth transition across the axial lines.
Edited on: Fri, Oct 27, 2017 at 5:01:21 AM
Tue, Oct 31, 2017 at 3:38:17 AM | Swept Blend for Basin
Tim79
Thanks Beaucoupnice - I'll give that a go.
[Revit MEP 2010] Stuck on VOID SWEPT BLEND
Thu, Jan 6, 2011 at 9:12:15 PM
Swept Blend
Fri, Nov 28, 2008 at 4:39:27 PM
Please help me with swept blend!!
Mon, Jul 28, 2014 at 3:31:15 PM
cannot rotate the reference plane of a swept blend
Tue, Feb 23, 2010 at 6:22:36 AM
swept blend with more than 2 profiles
Sun, Nov 18, 2012 at 5:21:24 PM
Page generation time: 1.5495
