66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Line Weight Drama
Thu, Oct 26, 2017 at 11:19:40 PM | Line Weight Drama
peerage
4.5 Stars: 2 Votes
Greetings All,
I'm having some serious head scratching over here, please help.
All of my furniture, doors, slab edges are plotting bold - is there a global way I can ajust this ?  Image attached.
Fri, Oct 27, 2017 at 5:05:41 AM | Line Weight Drama
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Assuming 1) Your view visibility settings are set to default ( i.e. not overwritten) and (2) Your furniture family lines setup via the family editor are ok, try - Manage - Object Styles and find the correct category and check the lineweights.You can also check your lineweights per scale via Manage - Additional Settings - Lineweights but this is less likely to be the cause assuming your BIM Manager set these correctly within your office template.
This user is online
Fri, Dec 15, 2017 at 12:54:56 AM | Line Weight Drama
peerage
4.5 Stars: 2 Votes
thank, you for your suggestions Beaucoupnice, It took until crunch time to figure it out properly, I'd fudged a few work arounds. It turns out the problem was with my phase filter overrides.
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:30 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:59 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:56 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:54 AM
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:24 AM
Page generation time: 0.8364
