132 Users Online (131 Members):
Forums >> Revit Building >> Technical Support >> Cannot Edit Tree Height
9 Posts No Rating |
I am not trying to edit the AccuRender tree...just the representational one when I am in a normal 3D. Even when I type a new height to my tree in its properties, the wireframe model stays the same. Any advice?
some trees are just an Autocad block that was brought into an RPC family. onto this dwg you can attach an accurender image and that is a set size, i don't think you can change it, but if you need to see the tree bigger in shaded view (or any other view but render) go to the family and scale up the tree there.
I've metioned this quite frequently...
Nest this planting family into a blank planting family and save and load it in.
This allows the ability to scale the dwg representation in the project. No need to lock or constrain it at all.
HTH.
We have just made a video tutorial showing how to adjust revit trees in height. It shows how to quickly create several families / types in different sizes, how they change in plan and elevation and also how to change it in the project.
The link to the video is under Tutorial / Parametric Scale on the following page: archigrafix revit trees .
Please send us your comments.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
trees |
Wed, Jul 3, 2013 at 1:55:49 PM
Tree |
Fri, Jul 16, 2010 at 4:19:25 AM
rpc tree |
Tue, Mar 31, 2009 at 12:01:03 PM
Tree library |
Mon, Oct 9, 2006 at 4:39:22 PM
Elements missing from elevation when behind a transparent tree |
Tue, Jan 27, 2015 at 7:00:25 PM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
