65 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> hatches break apart
Fri, Oct 13, 2017 at 9:36:16 AM | hatches break apart
archie456
3 Stars: 1 Votes
Hi,
I've using Revit 2016 and have an issue with Hatches on a project. I'm using the standard 'Stone' hatch and when I zoom in and look at it, all the lines which make it up don't meet each other and it appears as if the pattern has exploded apart.
I know this is an issue with AutoCAD with when a larch is drawn a very long way from the origin, but in Revit the project basepoint is right next to the building.
Any ideas of why this is happening?
Thanks.
Fri, Oct 13, 2017 at 9:49:27 AM | hatches break apart
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you sure the hatch pattern is any good?  The only time this happens in Revit that I have seen is if the hatch pattern was created wrong.
How To Turn Off Hatches
Mon, Feb 11, 2008 at 3:27:14 PM
View Breaks and break lines
Tue, Jun 26, 2012 at 6:49:55 PM
Material hatches
Wed, Feb 22, 2006 at 1:49:20 AM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:36 AM
Break Line & Weld sybol families
Wed, Apr 28, 2010 at 9:18:41 PM
Page generation time: 0.2365
