119 Users Online (115 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> RAILING NOT HOSTING TO ONE SIDE OF STAIR.
Fri, Oct 13, 2017 at 8:43:49 AM | RAILING NOT HOSTING TO ONE SIDE OF STAIR.
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
I HAVE TRIED ABOUT EVERTHING I CAN THINK OF. I HAVE ADJUSTED ALL LINES OFFSETS MOVED THEM AND NO LUCK. I HAVE EVEN COPIED A RAILING UP FROM A LOWER FLOOR THAT IS CORRECT AND IT BREAKS ON THE SECOND LEVEL ONLY. I CAN COPY THE SAME SET OF RAILING TO THE THIRD LEVEL AND IT WORKS. IT JUST BREAKS ON THE SECOND LEVEL
Mon, Oct 16, 2017 at 1:27:55 AM | RAILING NOT HOSTING TO ONE SIDE OF STAIR.
tim123
4 Stars: 19 Votes
Have you tried 'Pick New Host'?
Mon, Oct 16, 2017 at 6:02:10 AM | RAILING NOT HOSTING TO ONE SIDE OF STAIR.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Try editing the rail, so the sketch lines for the rail are showing. Ensure the sketch lines are sitting over the stair it is hosted to. If you are unsure if the railing is hosted to the right stair. Then try deleting the stair. If the railing vanishes as well, then it is correctly hosted. If not then you need to click the railing and click select host and click the stair. It may also help to edit where the stair to the sketch lines and where the lines stop and start at the top and bottom of the stairs, ensure they align with the final/first stair tread. Worst case scenario, just go through each line sketch part and edit the height as its required - this way a host is not required.
Default stair railing
Thu, Aug 26, 2010 at 1:08:26 PM
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:39 PM
Railing at stair bottom!
Thu, Feb 28, 2008 at 10:57:33 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
Stair will not host railing
Wed, Oct 10, 2012 at 12:19:23 PM
Page generation time: 0.4428
