36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Floor level
Tue, Oct 3, 2017 at 7:35:16 PM | Floor level
Pkken
What is the best approach to create floor elevation change (Drop down) for example balcony or bathroom floor.
Wed, Oct 4, 2017 at 4:31:10 AM | Floor level
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
I would simply place a floor in plan using the level most closely associated with it and ensure that the level of the new floor is set at the correct lower distance from the main floor. I wouldn't add in a level just for that floor. Too many levels in Revit just causes confusion and problems.
Wed, Oct 4, 2017 at 7:29:44 AM | Floor level
The reason Beau is recommending this is schedule and floor plan associations.
You can still associate the room and doors (etc) with the level they will be typically associated with.  You do have to modify the properties of floor hoted elements to do this.  For instance set the door or room elevation to the (-dropdown) from the level.
If you are doing a balcony or mezzanine, then I would use a floor level.
Site Elevation to Floor Level Problem
Wed, Jun 27, 2012 at 11:42:31 AM
I made a Level without a floor plan... but now I want one.
Fri, Dec 5, 2014 at 4:47:54 PM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:06 PM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:24 AM
Revit Arch 2013 - Roof - Starts at first floor level and second floor level
Mon, Sep 10, 2012 at 8:11:54 AM
Page generation time: 1.7093
