27 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Void cutting not completely working
Fri, Sep 29, 2017 at 1:56:50 PM | Void cutting not completely working
annahendrick
When I go to cut a void in a curved plane it doesnt work immediately, so I use the cut tool - it seems to work. But then when I go to divide the surface of the cut plane, it will only apply the pattern to the entire area of the plane (including the area that should be within the void). See attached pictures.
I've tried dissolving and remaking the forms in different orders a zillion times. I have no idea why a few planes are doing exactly what they should and others are not.
155809_mass_actually_still_there.PNG155809_mass_cut_at_bottom_with_void.PNG155809_pattern_latches_on_to_mass_thats_been_cut.PNG
Fri, Nov 24, 2017 at 1:27:12 AM | Void cutting not completely working
Jezzza
In all three images it doesnt look like the void is appearing in the wall at all
It looks like the "windows" are modelled in but not making a void in the wall. Might be something to do with the family? Windows should automatically cut a void in the host aka wall
Have you tried using Wall Opening tool under Structures tab? I did a curved wall (using Wall tool) and can cut a void
I tried using the Wall Opening tool on a modelled in component and didnt work, so that may be your issue
Is there a way to exclude what a void cuts into?
Wed, Oct 23, 2013 at 10:42:01 AM
Cutting wall end with in-place void - Revit 2018
Thu, Jul 6, 2017 at 5:08:31 PM
Wall Hosted Family cutting void into Wall
Mon, Aug 23, 2010 at 3:59:00 PM
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:44 PM
Cutting irregular openings in curved walls
Sun, Apr 9, 2006 at 7:45:40 PM
Page generation time: 1.9200
