101 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Is it possible to separate metal and glass doors swing color in floor plan?
Sun, Sep 24, 2017 at 3:58:12 PM | Is it possible to separate metal and glass doors swing color in floor plan?
GON3d
Hello everyone,
my question: is it possible to separate door swing colors in floor plan. For example I want that my curtain wall doors or glass doors would be in blue and normal wall door stay in black. Now changing door swing color affects all door types.
I'm using Revit 2018.
Mon, Sep 25, 2017 at 12:36:20 AM | Is it possible to separate metal and glass doors swing color in floor plan?
Elnazer2
4 Stars: 5 Votes
its is possible but you will have to edit the family , give the symbolic lines of the door swing a visibility parameter let's say " black Door Swings " and then copy the symbolic lines and paste it to the same place and with the same selection change the lines to another line type with the color you intend to use and give them a visibility parameter let's say "Color" and then in the project you can choose in your type which one to show
Mon, Sep 25, 2017 at 5:06:52 AM | Is it possible to separate metal and glass doors swing color in floor plan?
GON3d
Thanks! I'll try this way!
Mon, Sep 25, 2017 at 5:34:14 AM | Is it possible to separate metal and glass doors swing color in floor plan?
Elnazer2
4 Stars: 5 Votes
welcome , but that was for how to do it the way you want , but if it was up to me i would have separate families for each one ( glass doors and normal doors ) and each family with a single type of symbolic lines for swings
Doors-Swing projection doesnt match Panel in Floor plan
Wed, Dec 14, 2011 at 10:03:06 AM
Help! Need separate plan for floor patterns!
Fri, Jul 6, 2007 at 8:12:58 AM
Plan adjustable door swing issue
Mon, Oct 1, 2012 at 9:13:27 PM
Opposing swing on doors
Fri, Aug 24, 2007 at 12:16:07 PM
swing lines on casework doors
Fri, Jul 20, 2018 at 10:53:49 AM
Page generation time: 2.2620
