116 Users Online (115 Members):
Forums >> Revit Building >> Technical Support >> 'Trim' section details
Hi guys, basically I'm adding some details to sections on a project and there are some roof windows/ skylights which cut the gypsum at an angle but when i add in the insulation batts how do I trim them to the same angle? At the moment wherever I place them they are 90 degree. I tried trim etc but it doesn't work on batt insulation - any ideas? I just want the insulation to trim exactly at the gypsum line but I can't figure it out. I'm on 2016 but learning.
No way to trim these. I typically used a couple of smaller batts in this angled area.
Okay, that sucks. Some things I believe they could still incorporate from AutoCAD to make a few things even better. Especially since this is line work it would make sense. But I guess I'll try your idea see how it looks.
Creating a 'Jogged' Section Line |
Tue, Dec 11, 2007 at 8:26:06 AM
Trim and frame does not adjuts to wall as expected |
Wed, Mar 1, 2006 at 12:22:56 PM
Tricky Window Trim |
Thu, Mar 9, 2006 at 1:14:00 PM
Displaying a 'call out' tag from a section or plan on Elevations - Possible? |
Sat, Jan 20, 2007 at 10:42:49 AM
Section and Detail Tails |
Sun, Jun 18, 2006 at 9:30:05 PM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
