58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Custom Triangulated Curtain system on curved mass
Fri, Sep 15, 2017 at 1:40:05 PM | Custom Triangulated Curtain system on curved mass
annahendrick
Hi,
I've got a highly complex curved mass that I need to put a curtain system on. The issue is, I need the rectangular grid to also have a third mullion line added - diagonals going up in one direction. I cannot get this to work based on the basic patterns available- all patterns have diagonals going in two directions.  Adaptive components dont seem to work - the most I've been able to do is make an adaptive componenet that is literally just the diagonal lines, then I layer it over the standard curtain system. This is tedioius and doesnt line up perfectly though.
Is there anyway to modify or easily make a new pattern for surface division?
Thanks!
Fri, Sep 15, 2017 at 1:58:03 PM | Custom Triangulated Curtain system on curved mass
Curtain walls will not work for this, you will have to work harder on your adaptive components.
Triangulated Curtain System Mullion Problems
Thu, Nov 21, 2013 at 8:08:57 AM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:47 PM
Curtain system from mass - Revit 2014
Fri, Jun 17, 2016 at 12:20:49 PM
Curtain System from Mass - Mullion Joins
Fri, Dec 11, 2015 at 7:27:44 PM
Advice on Curtain Systems and Slabs from Mass
Tue, May 10, 2016 at 12:17:57 PM
Page generation time: 0.9533
