Forums >> General Discussion >> Revit Project Management >> Plan Region and View Range issue
Hi All
Please find attached Picture.
i have a multistoried building,
I am preparaing Second floor plan, but i need to show the content in first floor and ground floor landscaping items that is out side the second floor boundaries.
i used plan region, but i cant arrange it, when i adjust the view range, it shows items even in side the second floor boundary (i.e outside plan region boundary also)
Please find the pic for illustration.
Very much looking forward to getting solved this issue.
Sorry, i forgot to tell
I am using Revit 2017
Can you upload an image of your plan region that you drew? Your plan region needs to be outside of your second floor.
Hi
Please see the image.
I made it with view range, as plan region i cant change its visibility to light color.
now one more issue, i managed to change the line color and thickness (Beyond line).
But about color, i want all colors outside my actual plan as light(something like faded or halftone shade).
I would not use a plan region. I think I would use a first floor underlay.
I would also use underlay option and then linework tool for different representation. Then close the underlaying after linewrking and you have your needed lines.
plan region/view range window |
Mon, Feb 9, 2009 at 4:39:35 PM
View Range ignore Plan Region in linked files |
Thu, Sep 15, 2016 at 7:34:59 AM
View Range/Plan Region Visibility Controls in RCP |
Wed, Feb 1, 2012 at 11:20:33 AM
plan region |
Thu, May 3, 2018 at 4:53:08 PM
Pipe Symbols on a Plan Region |
Fri, Apr 5, 2013 at 1:29:47 PM
Members: | 2097105 | Objects: | 23163 | Forum Posts: | 152288 | Job Listings: | 3 |
