53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Material Aligning on extrusion
Fri, Sep 8, 2017 at 2:46:37 AM | Material Aligning on extrusion
Ramonvanderzwet
Hello,
Is there a way to set the material alignment on extrusion.
When i draw an extrusion in a plan the material on the sides are like the material library. But when i draw an extrusion in an elevation the material is rotated 90 degrees.
I know you can rotate this back but i want to know if there is a way to do this good at the start.
Thnx
Applying material to extrusion
Thu, Nov 6, 2014 at 10:28:03 AM
11
Mirror Material in Revit not Working
Tue, Sep 23, 2014 at 5:49:41 AM
Hiding edges of extrusion in my plant component
Thu, Oct 18, 2018 at 12:15:31 AM
re-joining (?) cut extrusion with extrusion
Tue, Apr 17, 2007 at 10:26:27 PM
material in renderings
Wed, Dec 12, 2012 at 2:14:22 PM
Page generation time: 0.6833
