32 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> turn on/off worksets in a linked model
Thu, Sep 7, 2017 at 5:05:48 PM | turn on/off worksets in a linked model
ledgewood33
wondering if it is possible to turn on/off worksets from a linked model e.g. we have a site model linked into our building model and on our site model we have a lot of trees and those trees are on their own workset in the linked model. while we are in our building model and have the site model with the trees on their own workset linked into our building model we would like to be able to turn off the workset the trees are on in the linked site model from the building model. is this possible and/or is there another solution. the reason for this is that the trees are slowing down our model
Thu, Sep 7, 2017 at 7:00:28 PM | turn on/off worksets in a linked model
You can contol everything in the linked model that you can in your own VG setting -  Look under VG.
Fri, Sep 8, 2017 at 3:39:17 PM | turn on/off worksets in a linked model
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
To turn off objects in a linked model globally. i.e. across all views, do the following.
Open the linked model, make it collaborative, create a workset called trees, place all trees in that workset, save and close. Open building model, go to manage links, select your site model, go to bottom of window and click on worksets, in worksets window close the trees workset. close.
That should do it.
This works especially well for references lines, levels and grids too.
? regarding controlling visiblity within linked files according to Worksets
Fri, Jul 2, 2010 at 10:01:41 AM
Autodesk A360 - Linked model don't appear
Wed, Jan 4, 2017 at 4:49:02 AM
Not able to place room copied from linked model
Wed, Mar 18, 2015 at 8:10:38 AM
linked file elements on host workset...help
Fri, May 4, 2012 at 5:46:59 AM
Turn off level lines in a linked model
Thu, Aug 28, 2014 at 10:42:48 AM
Page generation time: 1.3930
