27 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Creating a curtain wall system facade (Revit 2017)
Hello all. I would like to create a curtain wall system on my building but I am facing a few difficulties.
So the image of the sketch-up model is what I am trying to achieve. The attached image of revit is the current model i am working on. As you can see, i did in-place mass to create the external plane of the facade. I divided the surface of my massing. The panels that i am trying to achieve are 2400x600mm rectangular panels. However, when i input such dimensions in my divided surface, the grids will follow the shape of my mass. is there a way to keep the divided grids consistently 2400x600mm and parallel to the ground? Instead of it slanting and following the plane.
Double-Skin Facade as a "Curtain System" on a "Mass". |
Sat, Nov 21, 2015 at 7:10:28 AM
Need assistants on double facade.... |
Tue, Feb 24, 2009 at 6:30:13 AM
Revit 2017 |
Fri, Jun 17, 2016 at 2:53:58 PM
Creating curtain wall system on an angled wall |
Fri, Dec 16, 2011 at 4:01:22 AM
Using photos on panels of curtain wall? [ 1 2 ] |
Mon, Apr 19, 2010 at 9:04:53 PM
23
Members: | 2025990 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
