70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Masonry-concrete block - revit 2015
Thu, Aug 31, 2017 at 5:13:28 AM | Masonry-concrete block - revit 2015
FACTORIA
How do you add filled cells to a 8: concrete block wall in plan (in florida every 4' into a cmu and at corners, openings)..does a new column type have tobe created? does anybody have typcal wall families already created in concrete block?
Thu, Aug 31, 2017 at 6:57:28 AM | Masonry-concrete block - revit 2015
Nobody that I know of actually shows concrete block cells in plans, only in details. Walls are typically defined with a hatch that shows the difference of plain block walls and filled block walls.   If you want to call this out with automatic noes, see my post here.
Architectural 'colums' can be used for pilasters because they will assume the material of the wall they are placed against.
masonry walls?
Tue, Jun 22, 2010 at 5:35:51 PM
concrete wall and masonry wall to have different lineweights
Thu, Jan 6, 2011 at 12:39:04 PM
Split Face Masonry Block
Thu, Aug 3, 2006 at 6:25:54 PM
CONCRETE BLOCK SECTION .PAT FILE
Mon, Oct 10, 2011 at 3:31:58 PM
How to create masonry or concrete lintels and display them correctly?
Fri, Apr 9, 2010 at 3:42:59 PM
Page generation time: 10.9950
