52 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Revit 2018 - Changing wall fills specific to sheet
Hello. I may not be searching with the right terms, but could find no information about this.
My office would like to add sheets to our set where the walls are filled with a solid black pattern. On the main floor plans the walls are shown according to materials, but because we are a facilities management office, we would like to generate seperate plan views where the walls appear solid for mapping and interior space work.
I have created a new Dependant Plan, thinking I could modify he wall patterns with an Overide, but I am not getting the results I want.
As I am new to Revit, and we just switched to 2018 this month, I am still figuring out how to do quirky things like this. Any help or links provided would be greatly appreciated. Thank you.
You will probably want to set your view to coarse so that all walls are outside lines with no interior linework. They you can set a filter to fill all walls or do individually.
Read this as a beginning point.
Thank you. I will look it over.
Export fills to layers |
Fri, Sep 11, 2009 at 11:51:47 PM
Copying elements from old project to a new one in Revit 2018 |
Wed, Apr 11, 2018 at 3:32:49 PM
EXPORTING TO AUTOCAD- WITH NO COLOR FILLS |
Sat, Mar 31, 2018 at 3:07:56 AM
Changing Sheet References |
Thu, Sep 18, 2008 at 9:57:06 PM
Changing the wall reference of a ladder family in revit |
Wed, Oct 8, 2014 at 1:02:54 PM
Members: | 2034031 | Objects: | 23010 | Forum Posts: | 152214 | Job Listings: | 3 |
