72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Manipulating Schedules
Thu, May 25, 2006 at 10:14:07 AM | Manipulating Schedules
freestyle250
I am fairly new to Revit, so i am by no means an expert. I have been messing around with schedules a little bit and organizing a drawing index on the cover sheet. and after i started the schedule we have since added drawings. but the new drawings appear at the top of the list, not in the order where we need them. how can i edit the schedule and move them down into the correct place?
Thu, May 25, 2006 at 10:48:17 AM | RE: Manipulating Schedules
vdogg
It depends. If you want the sheets so that the sheet number is alphabetical, go into the schedule properties and click on sorting/grouping and sort by sheet number. If this is not how you want to see it, then what I normally do is create a new field for the schedule, and then number the sheets in the order I want to see them, and sort by the new field, and then hide that fiel, and the schedule appears as I want it. HTH
Sat, May 27, 2006 at 1:10:19 PM | RE: Manipulating Schedules
rwheat
I'm new to Revit and online forums too, so not sure if this proper way to inquire, but it is a related question. I'm simply trying to figure out how to create a Drawing Index from the schedule tool. In searching the Revit help menu I can't even find reference to it ...from this original thread it looks like you can, what am I missing
Mon, May 29, 2006 at 1:31:38 AM | RE: Manipulating Schedules
vnd
3 Stars: 2 Votes
Go to your view pull down, 'new' (fly out) and then choose 'drawing list'...
VND
Mon, May 29, 2006 at 4:10:01 AM | RE: Manipulating Schedules
rwheat
Thank you, I feel right silly now!
Tue, Sep 16, 2008 at 1:14:57 PM | Manipulating Schedules
dprado
Q1. I need to create a schedule for a Model Room - i will like to create a schedule with everything in it. The schedule should have plumbing fixture, furniture, materials,... Can someone help me?
Q.2 When creating a Plumbing Schedule i will like the Material & Dimensions to show how can i do this task?
Thu, Apr 10, 2008 at 11:23:57 AM
multiple schedules
Tue, May 1, 2012 at 1:04:42 PM
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:01:59 PM
Importing MS Word (or other text) into Revit
Wed, Jul 30, 2014 at 3:07:50 PM
Page generation time: 0.3355
