134 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Dimension line fixed distance from an Object
Tue, Aug 22, 2017 at 7:59:03 AM | Dimension line fixed distance from an Object
zakazai
Hi All
I want to place a dimension line exactly 600mm away from wall. please advise
i know how to use snap settings that uses between dimension lines, but i dont know how to make the first dimension line from the object.
Tue, Aug 22, 2017 at 8:18:27 AM | Dimension line fixed distance from an Object
Sorry, there is no way that Revit will control this, only the spacing between dimensions.   You will have to find another process.
"EQ" dimension on either sid eof a fixed dimension [ 1 2 ]
Sun, Aug 24, 2008 at 12:08:51 PM
15
Dimensioning questions
Sun, Jan 15, 2006 at 3:50:20 PM
Dimension or Detail Component?
Mon, Nov 18, 2013 at 3:24:17 PM
Why does it, when I click on a line or object...
Tue, May 3, 2011 at 8:12:21 PM
Elaveation / Section Lineweights by depth. screening by distance.
Fri, Aug 18, 2006 at 10:39:35 AM
Page generation time: 0.6706
