45 Users Online (44 Members):
Forums >> General Discussion >> Revit Project Management >> Revit Specific PDF Creator
Hi All,Just to throw it out there, I have been using Adobe for creating PDF's but for some complex views it blows the PDF size and the result is a slow regenerating PDF. I am printing with Vector settings the views do have surface patterns but no shading or images so it doesn't automatically print Raster. I have been advised to try out Bluebeam which have compression settings specifically to handle graphics, my question is how does everyone else get around this seemingly know issue, and is there a PDF creator which has Revit specific algorithm settings to handle the Graphics.
Arun
BIM Manager,
STH |
Try CutePDF
I have tested the same sheet with Adobe, Bluebeam, PDF exchange & CutePDF. The latter three file size were similar around 11mb, Adobe file size was around 3.5mb, but the regeneration issue was common to all.Adobe has around nine default presets, all of them have the same issue of slow regeneration, all that changes is the file size from the highest quality setting of 4.1mb to the small size setting of 3.5mb, changing the DPI doesn't do anything. Unless there is a specific tweak to the existing settings to fasten the loading and regeneration of the PDF which I am unaware of. It's certainly not a hardware issue too, I am surprised no one has come across this before.
Arun
BIM Manager,
STH |
Rpc Creator archvison |
Sun, Jan 22, 2012 at 10:20:41 PM
after revit export to pdf the file is wrong scale |
Sat, Nov 20, 2010 at 10:54:04 PM
why do my text look wonky when I make pdf files? |
Mon, Aug 12, 2013 at 12:22:06 PM
RPC creator free...What's the end? |
Tue, Apr 16, 2024 at 3:53:11 PM
.txt Conversion to .pdf |
Wed, Feb 8, 2012 at 3:43:28 AM
Members: | 2069800 | Objects: | 23097 | Forum Posts: | 152262 | Job Listings: | 3 |
