154 Users Online (153 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Column Join issue
Mon, Aug 14, 2017 at 3:31:42 AM | Column Join issue
zakazai
Hi
I have searched alot about the issue with my columns that join with wall
1: Architectural column joins wall, i edit the family and unchecked the option to join wall, and reloaded to project, but the existing column still not changing even if i used unjoin geometry option (i use Revit 2017), buyt it works if i create new column.
2: If i attach the top of the newly created column that dont join wall, it becomes again like columns under blue marks in the attached pic.
3: If i use Join geometry option with a structural column to wall, and then i want to take it back as unjoin option, it is not possible. still it looks like in the pic.
is there any option? or i have to make a generic model family instead of using column.
in my plan i want to look like the red marked column,
Wed, Oct 11, 2017 at 10:10:16 PM | Column Join issue
DavidBruinsma
Hi
I just did a quick sample of what you are trying to achieve.
An Architectural column seems to automattically join to the wall, and inherits the properties of the wall.
A Structural Column does not inherit the wall properties upon placement, and seems to retain its own material properties - and thus appears the way you intend it to appear.
I think the answer to your query is to use a Structural column family instead of an Architectural column family.
Cheers, David.
Join geometry - Structural column with wall
Sat, Dec 1, 2007 at 7:56:16 PM
Auto Join Concrete Column & Beams
Thu, Jul 1, 2010 at 2:08:31 AM
Beam Joins Not Working Correctly
Wed, Jun 27, 2012 at 5:42:48 PM
Stairs with column
Thu, May 29, 2008 at 8:32:10 AM
Adjustable Column Issue
Wed, Feb 1, 2006 at 6:20:58 PM
Page generation time: 0.8824
