Forums >> Revit Building >> Technical Support >> Wall Reveal 'surface material' is incorrect
Thu, Aug 10, 2017 at 2:14:19 PM | Wall Reveal 'surface material' is incorrect
gantonski
Hi everyone. i've searched the forum. so far all i've read is 'paint it!'. thats not an option, its showing the wrong material. here are the facts put as simply as i can:
1. there are three layers to the wall
- concrete (concrete patern)
- air space (no pattern)
- insulation (hatch with yellow)
2. I made a reveal for the wall, when i add it the surface of the concrete shows yellow, not the concrete surface pattern.
3. take my word for it:
- the concrete material has no yellow in it
- the profile reveal is only cutting through the concrete portion of the material
4. I've copy/pasted wall into a new empty file and the problem persists.
5. if i remove the insulation layer (which has the yellow) then the concrete no longer shows yellow
6. see attached...
so how can i make this display with the conrete surface pattern instead of yellow?
Thu, Aug 10, 2017 at 2:21:36 PM | Wall Reveal 'surface material' is incorrect
Follow the advice you read - PAINT IT!.   The yellow you see is something in other settings but it will never be the surface pattern.
Thu, Aug 10, 2017 at 2:49:00 PM | Wall Reveal 'surface material' is incorrect
gantonski
My only option is to pain 4 surfaces of every wall i make?
yikes.
Thu, Aug 10, 2017 at 4:13:52 PM | Wall Reveal 'surface material' is incorrect
A solution would be to use a stacked wall - 3 different thickness - then only cut the slope and paint that one surface.
Wall's surface pattern goes through the reveal in elevation view
Thu, Jul 12, 2012 at 10:46:52 AM
13
Can't devide window top reveal (can't apply material on outside reveal)
Fri, Jul 10, 2015 at 12:29:24 PM
reveal wall subcategory parameter?
Mon, Feb 26, 2007 at 3:42:52 PM
Parameters that don't act to constrain
Fri, Feb 2, 2007 at 10:37:01 AM
'Surface Pattern' and corresponding 'Region Fill' appear differently.
Fri, May 17, 2013 at 9:11:54 AM
Page generation time: 2.4530
