58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Surface on solid form getting split after being edited by a void form
Wed, Aug 9, 2017 at 6:28:44 PM | Surface on solid form getting split after being edited by a void form
jkeefe22
Thanks is advance to anyone who helps. I'll get right to the issue:
In Revit 2016, I have created an in-place mass (that is a 3D form) that in plan, looks like a distorted rectangle (its curved). I have made an additional void form in the mass to make the top of the mass have a surface that sweeps up in one corner. While this resulted with one form, the top surface was split into two: one that is flat, and a corner that curls up.
What I need is to be left with ONE top surface that is flat at first, then curls up in the corner. I have created a custom UV grid and I want it to follow the top surface as it curls up. (The desired custom UV grid is overlayed on the form)
I need the top surface to be a single piece so that when I put adaptive curtain wall panels onto the UV grid, there is no kink where it starts to bend up. In other words, I need the transition from the flat section of the surface to the curled section to be seemless (like the rest of the curve).
Thanks again for any help.
Edited on: Wed, Aug 9, 2017 at 7:42:12 PM
void form and cuttng void form
Fri, Jul 9, 2010 at 12:39:02 PM
Void form issues once again. Few question
Thu, Mar 31, 2016 at 2:47:22 PM
VOID form will NOT work! [ 1 2 ]
Mon, Jan 30, 2012 at 3:00:24 PM
22
Can you apply divide surface to a revolved form?
Wed, Jun 12, 2013 at 3:46:54 AM
Creating Family's - Hatching of Solid Form
Wed, Aug 29, 2007 at 2:09:25 PM
Page generation time: 1.2091
