66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> 3d Visibility Question
Thu, May 25, 2006 at 7:59:05 AM | 3d Visibility Question
joblue
I have a question about 3d visibility. I created a massing model, with different masses on different levels...nothing too fancy. Is there a way to filter these elements on/off either by level or some of the other attributes that I have tagged the mass elements with?
Tue, Jun 6, 2006 at 1:35:55 PM | RE:
oceanmandy
You best bet is probably to use phases and filters. If that does not work well put your create-in-place elements in under different families e. i. 'casework', 'walls', 'floors' etc. (or after created -edit your family. Select object and pick family types) This is a way to 'cheat' to make the program do what you want.
Stair Visibility Question in 2008
Sat, Sep 1, 2007 at 1:39:43 PM
Question about rebar visibility in Shaded view
Mon, Apr 29, 2013 at 2:19:19 PM
Visibility question
Thu, Feb 10, 2005 at 6:21:01 PM
visibility graphics question
Mon, Jun 15, 2009 at 1:33:53 PM
Visibility Parameter in Room Tag
Fri, Jun 4, 2010 at 6:01:10 PM
Page generation time: 0.7754
