37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall panel array
Thu, Aug 3, 2017 at 7:10:56 AM | Wall panel array
Lavender20
Hi All! I have an adjustable length start panel adjustable length end panel, and a middle section array of fixed length panels. For the middle section, the length parameter must adapt to multiples of the fixed panel length. My current thinking: I need to specify a rounddown to a multiple of Fixed panel length. How do I insert the rounddown, specifying x as the fixed panel length, into an existing formula? e.g. Length=Base-Start-End. Length must round down to the nearest x (X is fixed panel length).
I would really appreciate the help!
Thu, Aug 10, 2017 at 1:37:30 PM | Wall panel array
marmiketin1
4.5 Stars: 10 Votes
For rounding down in revit formulas you can do it as such:
rounddown(Base-Start-End)
You can also do this to just one element such as rounddown(Base) if you want to make sure numbers are integers instead of doubles.
Array removing existing parameters
Sun, Feb 22, 2009 at 7:46:44 AM
Arrayed Array
Thu, Oct 7, 2010 at 5:20:22 PM
Revit 2014 - Array within Profile Family
Fri, Aug 29, 2014 at 9:35:43 AM
Curtain wall family with parametric array
Tue, Sep 17, 2013 at 9:27:04 PM
Making Last Panel in Curtain Wall Cropped Instead of Squeezed
Thu, Feb 11, 2016 at 10:57:22 AM
Page generation time: 0.7338
