42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2018 Elevation Tag Location
Fri, Jul 28, 2017 at 11:07:11 AM | Revit 2018 Elevation Tag Location
ericlovell
So my office is working in Revit 2018 and we have noticed a new little nice, but somewhat annoying feature for Elevation Tags. It's great that the elevation tags display in the same location on every plan in the project, but we are curious is you can turn that off for specific plans. We have them on in our site plan, which is a different scale, and the tags overlap the building because of this feature. If there's a way to configure this, please respond. Thanks
Fri, Jul 28, 2017 at 12:07:32 PM | Revit 2018 Elevation Tag Location
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
If you hover over the elevation tag's arrow point, select it and go to properties, there is a parameter in properties to "Hide at scale coarser than". Change that and it won;t show at larger scales.You can select and move the elevation tags wherever you wont by the way and it wont change where the elevation cut is. The location of the elevation cut will only change if you select the elevation and change the bounding blue dashed lines.
Fri, Jul 28, 2017 at 12:26:33 PM | Revit 2018 Elevation Tag Location
ericlovell
Yeah, I know about that. They want the elevation tag to show up on the site plan. We are trying to get the annotation tag to be in a different location on the site plan only. It's just another little issue with Revit not dealing with scaling very well.
location of the elevation tag and section tag
Tue, Aug 10, 2010 at 10:07:11 AM
Sim location issue on Elevation tag
Wed, Nov 5, 2008 at 11:50:17 AM
Tue, Dec 7, 2010 at 4:56:01 PM
Tag Leader Origin Location
Sat, Jun 23, 2018 at 3:53:43 AM
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:43 AM
Page generation time: 2.6441
