Forums >> Revit Building >> Technical Support >> Sections, different level/views
2 Posts No Rating |
I have created sections on a level that I will not be using in my final presentation and have detailed it.
Is there a way to make it show up in different levels/views?
Thanks!
Select the section line and view it in a section that crosses that section - you will see the extents of the section, which you can adjust to include the desired level.
If the section is NOT a multistory section, the place new section markers using the 'reference other view' setting and use the view that you already created.
This is a great tool because the section callout doesn't have to be in the same place so use it where you have similar walls around your building.
2 Posts No Rating |
Thanks for trying to help me, but I can't find anything that works.
Makes me think it may not be able to be done in 2013. (Sorry I didn't state year earlier)
I tried running a new section across the one I want on an other level, but don't understand a way to work with it.
I've tried looking for "Reference other views" with no luck.
Any thoughts?
Thanks,
Gary
Reference other view has been around since I began with ver 8 - your process is probably not correct.
Watch this video.
Sections lines not visible in certain plan views. |
Wed, Dec 14, 2005 at 11:30:16 PM
sections and level lines |
Wed, Jul 12, 2006 at 4:39:51 PM
levels in sections/elevations |
Tue, May 9, 2006 at 11:18:22 AM
Easy way to turn off all but specific sections? |
Thu, Jan 21, 2010 at 1:59:01 PM
From Wall Sections to Drafting Views |
Fri, Sep 25, 2009 at 10:22:09 AM
Members: | 2102455 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
