110 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Using Filters for Phasing
Thu, Jul 27, 2017 at 7:44:15 AM | Using Filters for Phasing
mark7321
    An architect we are designing a building with likes to use Filters instead of Phasing to control the visibility of elements in a model. The architect gave us the txt file that has the shared parameter to insure that all clients have the correct shared parameter. However, when I try to create the Filter that the architect wants us to use I can't get the shared parameter to appear in the "Filter By" window. Under Categories I have unchecked the exact elements that was requested by the architect. Also, if I look in the Properties window of the shared parameter the Name, Discipline and Type of Parameter are correct.
PHASING
Tue, May 20, 2008 at 1:57:26 PM
Hiding Certain Doors from a Door Schedule
Thu, Nov 19, 2009 at 12:33:08 PM
door lines at floor plan
Tue, Jan 16, 2018 at 12:17:56 AM
Filters for Phase
Tue, Dec 20, 2011 at 12:15:38 PM
Existing Filters into a Callout
Fri, May 10, 2013 at 10:22:08 AM
Page generation time: 0.8774
