80 Users Online (78 Members):
Forums >> General Discussion >> Revit Project Management >> Changing Dimension object in Array
0 Posts No Rating |
Hi All
a particular louver window family i want to make as follows.
1: i made a big extrusion as frame applying height and width and length,
2: Then i made holes in it for louwer panels as void extrusion, i made one void extrusion, and i want to array it, array works good.
3: i tried to change the width of void opening that is linked to a parameter,
but the dimension not changing and getting error message. if i ungrop and avoid array, i can change void dimensions, but in array i cant.
is there any solution for changing dimensions of objects that is in array so that all objects will change its size in the array.?
How big are the holes? If they are tiny - like you would see in perforated metal, then just use a mesh material instead of actually cutting out holes. There is a few default metal steel mesh materials in Revit you can use. Cutting out holes will make for an overly complicated family and will slow down your model if you use them too many times as Revit struggles to process the thousands of faces and edges.
0 Posts No Rating |
Hi
I made it
Please the attached family.
but this louvered windows are only from 3 panels or more.
what i should do for a two panel one.
is there a way to switch of array for single panel?
please find the family
Dimension line fixed distance from an Object |
Tue, Aug 22, 2017 at 8:18:26 AM
moving object with an array |
Fri, Feb 13, 2009 at 11:46:08 AM
"EQ" dimension on either sid eof a fixed dimension [ 1 2 ] |
Sun, Aug 24, 2008 at 12:08:50 PM
15
Radial array in Families |
Tue, May 28, 2013 at 3:04:01 AM
Array along a curved path |
Tue, Nov 11, 2014 at 9:11:45 AM
Members: | 2081118 | Objects: | 23122 | Forum Posts: | 152272 | Job Listings: | 3 |
