66 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit crashes when placing keynote legend
Sat, Jul 22, 2017 at 5:29:15 PM | Revit crashes when placing keynote legend
Ayelsea
I am using Revit 2014
Hi, I am still pretty much a newbe, so perhaps I am doing something wrong, but Revit crashes (it just closes and that's it) everytime I try to drag my Keynote Legend into a sheet.  Is there another way to bring a Keynote Legend into a sheet or is this the only way?  Does anybody have any idea why Revit crashes when I try to do this?
Sun, Jul 23, 2017 at 7:12:04 AM | Revit crashes when placing keynote legend
Not a normal or even talked about problem. Make sure you have all of your updates. Audit your file.
Sun, Jul 23, 2017 at 3:01:30 PM | Revit crashes when placing keynote legend
Ayelsea
I think auditing it did the trick because it works now, so thanks a lot WWhub.  Regarding the updates, are you refering to windows updates or are there Revit updates?
Mon, Jul 24, 2017 at 6:52:14 AM | Revit crashes when placing keynote legend
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There are Revit updates that you should keep up on.
Mon, Jul 24, 2017 at 7:52:52 AM | Revit crashes when placing keynote legend
blue442
blue442 Avatar
This is where the updates are listed:
https://knowledge.autodesk.com/support/revit-products/downloads?release=2014
Tue, Jul 25, 2017 at 2:07:44 PM | Revit crashes when placing keynote legend
Ayelsea
Thanks teafoe5 and blue442, I'll make sure I keep up on those.
Keynote Legend Not Showing Keynote Text
Fri, Sep 6, 2013 at 11:41:00 AM
12
Keynote Legend For Each Detail Sheet
Wed, Oct 3, 2007 at 1:29:25 PM
Keynote Auditing
Tue, Feb 1, 2011 at 10:30:30 AM
Element keynote in legend - in 2014
Wed, Apr 16, 2014 at 10:54:02 AM
How to get a horizontal keynote legend with columns
Fri, Apr 8, 2011 at 6:17:55 AM
Page generation time: 2.5747
