67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Default templates and families missing from Revit 2016
0 Posts No Rating |
I am not entirely sure how, and I know that this is a common issue, but all of the default templates and families are gone from my Revit. I have tried reinstalling the Revit content libraries to no avail and I have been scouring Revit and other Autodesk forums for the solution. It seems like I'm just missing a step, is there anyone that has a solution?
Be well,
Joe Killian
Mass Design House
I doubt that they are gone, your pointers just have not been set or have been changed. Click on the Revit R and under that dropdown you can reset the pointers to your libraries.
0 Posts No Rating |
Thank you so much! Please pardon my ignorance, but where do those libraries typically reside?
It depends on the year and where you tell it to place them during installation. Look at something liked this:
C\Program Data\Autodesk\RVT2016\Libraries...
0 Posts No Rating |
Now I've got the file location for family templates set to this:
C:\Program Files\Autodesk\Revit Structure Content 2016\ContentPacks\en
When I went to set it to that, Revit read that folder as being empty, but when I accessed it outside of Revit, the file was populated by a list of XML documents. Does that make any sense? All that being said, none of the default families have appeared in Revit for me.
I would try a full reinstall or try to uninstall the Revit Content Library Only . Is your Revit license a valid version from AutoDesk? If not, the setup files may not be fully populated with all the libraries.During the install some versions of Revit offer you the option to install the OOTB library. Did you tick that option?Some further options:How to install additional Librarieshttps://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/Installing-additional-Revit-content-libraries.htmlUninstall the Revit Content Library Only.https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/Revit-Templates-and-families-not-installed.htmlRevit Content Installation Problemshttps://forums.autodesk.com/t5/revit-architecture-forum/revit-content-installation-problems/td-p/5656993I hope this helps.
The path you showed is incorrect. Your path has to be different for templates and families and will end in a folder by the appropriate name. ... teplates etc
Modifying Default Family Templates |
Mon, Apr 26, 2010 at 2:20:23 PM
Revit Architecture 2013 Missing Families on Install |
Sat, Oct 13, 2012 at 9:54:27 AM
revit architecture 2012 installation |
Fri, Sep 23, 2011 at 4:39:25 PM
Families templates |
Thu, Jul 16, 2015 at 12:30:11 AM
Revit 2016 |
Thu, Mar 31, 2016 at 11:00:08 AM
12
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
