97 Users Online (96 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Revit files Linked are transparent when using Electrical Template! REVIT 2017
Fri, Jul 7, 2017 at 7:07:11 AM | Revit files Linked are transparent when using Electrical Template! REVIT 2017
rennyrt27
I am starting a new project on Revit, I'm using the Default Electrical Template, but when I link the Revit file of a building, it becomes into a transparent building and I can see everything beyond the structure.
I used the Revit 2016 and I have the same problem.
If I use a different template (Mech, Arch or Struc) I don't have that Issue, but I need to use the electrical one.
There's a picture attached to make it more clear,
Fri, Jul 7, 2017 at 11:19:03 AM | Revit files Linked are transparent when using Electrical Template! REVIT 2017
3.5 Stars: 397 Votes
The view you posted is not transparent.
Views are controlled by templates and by discipline and then by VG settings or filters.  I do not see a template applied.  Setting your discipline to coordination will change how this view is shown but that may not be what you want.
Reloading Linked Files - Lost Sheet Views
Tue, Aug 23, 2011 at 8:52:01 AM
Hidden Object comes back after changing View Template
Wed, Apr 19, 2017 at 12:24:45 PM
Revit 2015 Missing Family Template Files
Thu, Nov 13, 2014 at 6:45:25 PM
View Templates and V/G Overrides, Revit Linked Files
Sat, Jul 9, 2016 at 12:37:06 PM
How does one keep a linked model from becoming transparent
Thu, Nov 20, 2014 at 8:39:12 AM
Page generation time: 1.8281
