56 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> "Not for construction" turn on and off
Hi, I am learning Revit and have just created my titleblock (which is really just kind of a copy of my old CAD titleblock that I have been using for many years; with the exception of text labels, which I think are totally awesome). So I have an item that is basically just a rectangle with text inside of it that says, "not for construction". I would like to easily be able to turn this thing off and on (in CAD I just had it in it's own layer which I would simply turn on and off. The lines have been assigned to a subcategory which I was planning on using to turn it on and off, but I can't figure out how to put the text in the subcategory also.
Does anyone know an easy way that I can accomplish this goal? By the way, I am planning on doing something similar with my architect stamp.
Thanks in advance.
Edited on: Thu, Jul 6, 2017 at 6:48:33 PM
Use visibility parameter. In the title block family, create a text (I don’t think you need a label for that) -> select it (1) -> click on a builder button (2), I think that's how it's called -> create a new parameter, either Type to control the text on all t.b., or Instance to turn your text on/off on sheet by sheet basis (3, 4) -> load it to your project -> select the title block -> edit type (5) -> check or uncheck visibility parameter (6).
Also note that if it is a 'Type' parameter it will affect all your sheets, while an 'Instance' parameter will only affect the one sheet.
Awesome, this worked perfectly, thank you so much pijpiwo and tim123!
When I copy an "existing" element it reverts back to "new construction." |
Mon, Jun 16, 2008 at 2:38:24 PM
Calculated field on sheet to state whether "numeric" or "Alphabetic" no. used |
Tue, Jul 10, 2012 at 7:07:05 AM
changing the "family" and "type" names |
Mon, Apr 2, 2007 at 5:33:49 PM
e-class entitled "Revit for Use In Residential Construction". |
Fri, Mar 28, 2008 at 1:23:52 PM
pattern wont "turn" with sweep |
Mon, Nov 18, 2013 at 5:58:29 AM
Members: | 2088707 | Objects: | 23142 | Forum Posts: | 152276 | Job Listings: | 3 |
