86 Users Online (84 Members):
Forums >> General Discussion >> Revit Project Management >> How to create an angled Curtain Panel
Hi All,
I've seen answers to similar questions on here, but none really fit with what we are trying to do.
We have a curtain wall, with the vertical grids sloped at -15degrees. The horizontal are left at 0deg. Screen shot attached.
This forms a skewed curtain grid. What the project architect wants do do is divide each panel diagonally into 2 separate triangles (each panel can contain 2 triangles which have separate material parameters). Screen shot attached showing detail lines for intent.
I have tried building a new panel family, however this only changes about 6 or so panels in the center. Will i need to create additional panels for all of the edges? Is there a better way of doing it?
We are using Revit 2015.
Any help would be much appreciated.
Thank you in advance.
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
You can make this curtain panel family using the "curtain panel pattern based" family template and then changing the grid to be triangles.
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
Creating curtain wall system on an angled wall |
Fri, Dec 16, 2011 at 4:01:22 AM
Curtain Panel Yes/No Parameter |
Wed, Oct 3, 2012 at 5:45:00 PM
Schedule curtain panel by level? |
Fri, Sep 2, 2016 at 4:40:25 PM
Panel selection in curtain walls |
Tue, Jul 22, 2014 at 4:54:06 PM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
