Forums >> Revit Building >> Technical Support >> base trim
Could anyone recommend which command I should use to create a tile base trim.
Thanks
Gar
... tile base trim? If you could elabourate on what that is, perhaps post an image on the kind you're after? (sorry, terminology is a little different where Im from...)
haha, but whatever it is I'll probably suggest an in-place family
A trim which is added on the bottom of a wall. It is like crown moulding for the floor.
Gar
If you are on Revit 9 there is a new family called 3D 2pick Family that will let you do that, it is a "generic model line based" if you need more info I will be more than happy to help you
I am using revit 8.1
Gar
Load your own Profile.rft family then
Modelling... Host Sweep... Wall Sweep
Properties... Edit/New... and select your profile family
Or if you want the Sweep to reside on all of the walls then
Select the wall... Properties... Edit/New... Edit Structure
Preview in Section View... Sweeps... and Load your Profile.rft family
It's not unlike the reveals you asked about earlier.
Skirtings? There are a couple of ways to make them, like you can use the wall modifier to host a sweep, but this way runs into problems real quick (skirtings dont go through walls etc.)
It does depend on how you like to work, but the best way we are finding is using in-place families. The learning curve is a little steeper but once you get the hang of it you can do a big house in under 10 mins. Draw your profile as a family and load it into the drawing (you could draw a couple of different profiles and have options). Then just draw sweeps (reference plane as the floor level) and specify the profile you want.
There are alot of resons why in-place families work very well; you can turn the visibility of the skirtings off in plan views, you can set the material and profile up to be parameters so changing the skirtings through the whole house is as simple as editing a family parameter...
Hope this helps, if you arent talking about skirting boards Im sure it will apply anyway!
Post edited on 2006-05-25 18:00:45
Thanks, Guys I guess it's the same as the reveal question I had on my other post.
Gar
9 Posts No Rating |
I have base trim on my walls, but I do not want it to show up in plan. How can I turn this off? Thanks, Megan
" I have base trim on my walls, but I do not want it to show up in plan. How can I turn this off? Thanks, Megan " this should provide you some info on the subject http://www.revitcity.com/forums.php?action=viewthread&thread_id=7003 HTH
Base trim in plan |
Fri, Jul 25, 2008 at 10:14:58 AM
trimming trim corner. |
Wed, Feb 1, 2012 at 12:09:41 PM
door trim stops short of floor |
Wed, Jul 24, 2013 at 3:24:32 PM
Trim Roof Facia |
Sun, Jul 3, 2016 at 12:18:25 PM
wood trim in revit arch 2009 |
Thu, Jul 31, 2008 at 4:53:32 PM
Members: | 2030522 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
