64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Move a level without deleting objects on that level
Mon, Jul 3, 2017 at 1:53:56 PM | Move a level without deleting objects on that level
evefielding
Our pads changed and I would like to move a single level up 1'-0". (not the project, just 1 independent level). When I do this, Revit deletes all of the information related to that level. Floors/Stairs/Walls etc. Thoughts? I can't figure out why this happens.
Should I just make a new level and attach everything to that? This will be very time consuming and I would prefer not to do this.
Mon, Jul 3, 2017 at 2:43:42 PM | Move a level without deleting objects on that level
Not sure what you are doing....
Open an elevation or section that shows the levels and either dimensions level to level or level elevations.  You might want to lock all level to level dimensions, except the one to your level, then change the dimension or level elevation.
Tue, Jul 4, 2017 at 5:20:24 AM | Move a level without deleting objects on that level
Elnazer2
4 Stars: 5 Votes
i had this problem once , it happened when i moved the level or when i change the value of the dimension between level to level , the dummy solution that worked for me is , calculating the levels final height and put the number in the level directly ( its dummy , maybe it won't work , but it's worth trying )
Mystery of the deleted level tag.
Wed, Aug 20, 2008 at 3:20:55 PM
deleting levels without deleting associated objects on it.
Thu, Aug 1, 2013 at 6:20:36 AM
objects from 2nd level appearing in 3rd level why?
Mon, May 20, 2013 at 4:35:42 PM
Move objects with level change
Mon, Sep 12, 2005 at 10:11:17 PM
deleting level advice
Mon, Dec 21, 2015 at 3:30:11 PM
Page generation time: 1.1609
