101 Users Online (100 Members):
Forums >> Revit Systems >> Technical Support >> Warning for placing family on too much of a slope...
The majority of my families use a type catalogue. With this I use somewhat of a failsafe to make sure people are inserting them correctly rather than just dragging them into the project (this happens a lot!)
By this, I mean I have a red box drawn around the model with 'DO NO USE' in big red letters. The unit description is also set to DO NOT USE. This red warning has a visibility parameter which is only set to zero by the text file along with the correct description.
If the unit is dragged into the project they see the warnings, if they go through the insert-->component route they don't see it.
What I would like to know is, is there a way of achieving something like this of when a family is placed on a surface that is outside of a given tolerance. What I mean is, our units must be installed on a flat surface or a sloped surface of no more than 10° from flat.
Can I have a visual warning appear if the model is placed on a surface that it more than 10° off of flat? I'm guessing 'no' but I'd love to hear if you lovely people have a special trick for this.
Edited on: Mon, Jul 3, 2017 at 3:59:52 AM
I would personally just set the family to 'always vertical' and then if I actually need it to slope I would add parameters within the family to do this. Not really sure what would ever have the need to only be sloped between 0 and 10 degrees though.
I dont think you can detect the slope of a face that a family is placed on in revit with the default functions. There might be a dynamo or python script that accomplishes this.
Thanks for the reply. The model is a vertical discharge extract fan that must be mounted flat or within 10 degrees due to the gravity-operated backdraught flaps on the top. I didn't think it was going to be an easy automatic thing. Might just make it work plane based and manually warn of the constraint.
Placing components on a SLOPE |
Thu, Jun 11, 2009 at 11:10:12 AM
Warning Message When Placing Mass |
Sun, Jun 5, 2011 at 12:00:26 PM
Concrete Placing Boom Family/Model? |
Mon, Jul 18, 2011 at 12:55:18 PM
Warning Message question |
Wed, Jul 10, 2013 at 3:19:14 PM
Roof's wont slope :( |
Mon, Apr 2, 2007 at 5:34:05 PM
Members: | 2022270 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
