Forums >> Revit Building >> Technical Support >> Hidden Reference Planes disappeared
Hi everyone!
Here is my problem: I've hidden all reference planes (by category) in the false ceiling view but now I'm not able to turn them on again. Toggling the bulb "Show all hidden elements" there's no reference plane!
Of course, in my first floor view the planes are perfectly shown.
What to do?
Many thanks to those who will help me.
Make sure ref planes are cutting through the view cut plane in RCP.
As pijpiwo said you need to make sure the reference planes are actually being cut by the reflected ceiling plan. Cut a section in the first floor plan and check where the top extents of the reference planes are.
The same thing can happen in elevations with levels. If the level does not extend into the view of the elevation you wont be able to see it.
Actually they are cutted by the ceiling plan (@ 2.20 m).
I didn't change anything but the visibility of the reference plans in the ceiling plan.
So, before doing that, I could perfectly see those reference planes in the ceiling plan.
Look at VG....
Actually, I did but... I'm not able to localize RP.
In which tab I find them?
Found! (in the annotation tab). Autodesk should add a search box.....
In fact, they where toggled off. Now, I got my reference planes back!
Thanks!
Sometimes self discovery teaches you more.....
....I have found this to be especially true with Revit
reference planes |
Wed, May 24, 2006 at 10:19:13 AM
Listing the Abilities of Reference Planes |
Sun, Sep 9, 2012 at 9:24:08 PM
Reference Planes |
Tue, Dec 4, 2007 at 10:01:57 AM
Detail Lines and Reference Planes |
Tue, Sep 20, 2016 at 2:37:47 PM
reference planes |
Thu, Mar 26, 2009 at 3:14:11 PM
Members: | 2097957 | Objects: | 23164 | Forum Posts: | 152289 | Job Listings: | 3 |
