76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Duct won't tap to oval duct.
Tue, Jun 20, 2017 at 2:55:37 PM | Duct won't tap to oval duct.
jeeenyuss
I am all out of ideas.  I'm simply trying to create a duct that taps to the side of an oval duct.  No matter what I try, it keeps saying that "No auto-route solution was found."  There are no obstructions.  They are both at the exact same offset.  I am becoming incredibly frustrated.  This makes no sense at all, because it was working yesterday.
Does anyone have any ideas on how to fix this?
Tue, Aug 22, 2017 at 12:38:49 AM | Duct won't tap to oval duct.
zakazai
You need to create a duct fittings family
with two connectors, one on each end.
at one end give recatangular duct connector, (select connector then change to rectangular), and other end ovel connector.
you need to make proper 3d model as per requirement.
this is one of the very advanced families of revit MEP. if you really want to learn it then use the link below.
and learn about duct transition.
https://www.pluralsight.com/courses/revit-mep-fittings-family-creation
How to get an oval duct in a model that doesnt have it in 2012
Sun, Sep 4, 2011 at 7:43:25 AM
Flat Oval High Pressure Duct???
Sat, Oct 17, 2009 at 7:48:59 AM
Revit Systems duct connections
Thu, Jun 11, 2009 at 9:32:41 AM
Eccentric Duct Fittings?
Thu, Dec 15, 2011 at 10:58:31 AM
Duct Fitting Issue
Tue, Apr 1, 2014 at 1:16:35 PM
Page generation time: 2.2020
