80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> New wall trasparent shading.
Tue, Jun 13, 2017 at 4:06:09 PM | New wall trasparent shading.
jbalsamo
We are working on a project where we would like to shade the new walls with a transparent shading so that the matial hatch will still show (i.e. a CMU wall whould still have the cross hatch but it would also be shaded gray).  I have tried phasing but this does not allow for transparency to the solid fill.  does anyone know of a way to achieve this?
Wed, Jun 14, 2017 at 12:31:33 AM | New wall trasparent shading.
Elnazer2
4 Stars: 5 Votes
i think the only option is to set your view to shaded ( shaded color on material and surface/cut pattern similtaniously )and adjust the other elements to show up correctly but that never work flawlessly , you will need some manual ovverrides
Wed, Jun 14, 2017 at 12:50:36 PM | New wall trasparent shading.
jbalsamo
This would work, except i would have to go and change all of the material shading options on all of the matieal used in the plan.  i would think there would have to be another way.
Thu, Jun 15, 2017 at 7:46:15 AM | New wall trasparent shading.
We have typically always used phases with existing elements set to light (screened & sometimes filled) and new as normal.
Exception in Visability Graphs
Mon, Aug 6, 2012 at 8:05:59 AM
Wall Materials and shading.
Fri, Jan 30, 2009 at 4:01:22 PM
Shading Toolbar
Tue, Jun 22, 2004 at 9:54:36 PM
Mesh Sun Shading Device
Fri, Apr 16, 2010 at 1:52:54 PM
TOO DARK Shading with Edges Revit 2009
Mon, Aug 25, 2008 at 6:57:19 PM
11
Page generation time: 1.3713
