66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Arc Curtain Wall with double Curvature Profile
Mon, Jun 12, 2017 at 11:26:24 AM | Arc Curtain Wall with double Curvature Profile
boereod
Hello guys,
I'm really frustrated to get this to workout in Revit instead of building the Massing in Rhino and them bring it into Reivt all the time.
Basically, this is a facade study for a project. So the solution should be accomodating and adaptive to future minor changes. In plan (see attached) all edges are arcs and they extrude up with different lengths so that in elevation you will see the curvature of the facade. There's also one corner that is a sweep condition where it changes 3 dimensionally. (see attachments)
What I have right now is the massing file from Rhino and I attached Curtain Systems onto the massing. But the problem is everytime we try to change the massing slightly I would have to model it in rhino first and fix all the surface direction issues and the UV issues and then bring it back to Revit. It's been quite hectic. Another problem of this approach is that since there are different types of the curtain walls but then they dont line-up with each other. I have also tried to build the in-place massing and then the curtain wall grids dont stay straight to the x and y axis (we are trying to get the trimmed edges instead of the pattern behavior in Revit).
I dont know what will be the best solution do this and if anyone has an experience on similar situation please help!
Revit 2017
Mon, Jun 12, 2017 at 2:05:00 PM | Arc Curtain Wall with double Curvature Profile
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Have you tried massing it in REVIT ? then using the wall, floor, roof 'by face' tools. They will update after you modify the REVIT Mass.
Sat, Aug 5, 2017 at 2:49:04 PM | Arc Curtain Wall with double Curvature Profile
sarangj8
using adaptive components would be useful if changes are going to take place. a
Double curvature curtain wall family problem in revit 2010
Thu, May 14, 2009 at 7:12:35 PM
join conditions of double curvature curtain wall system in revit 2010
Tue, May 12, 2009 at 3:43:19 AM
curtain wall mullions
Thu, Apr 5, 2012 at 1:16:07 AM
Arc Walls with curved top?
Thu, Aug 7, 2008 at 2:04:21 PM
CURTAIN GRID + DOUBLE DOORS
Sun, May 30, 2010 at 10:20:45 PM
Page generation time: 0.9288
