Forums >> Revit Building >> Technical Support >> some pop-up menus do not appear
On the Insert tab: I cannot load any families, insert files from other revit projects, or insert images. The pop up menu does not appear. It grays out like the command is in progress but no menu appears. I CAN link a CAD file, link a Revit file, & manage Images. Those menus pop up. Its as if the menus are off the screen & I cannot see them.
I have recently upgraded my monitors so I thought that might be the problem. I have tried different display resolutions. I tried using one monitor instead of two. I tried going back to my old monitors. I restarted the program, restarted my computer, downloaded service pack 2 for 2017, & reinstalled Revit 2017. Nothing has worked.
Has anyone had this issue? I am using Revit 2017 on Win 10 with 24" Dell monitors at 1920x1200 res. Nothing else seems to be off the screen on any other programs.
Thanks,
Wade Lavignette
I figured it out.
The dialog is opening off-screen. After selecting the Load Family tool on the problem machine, do the following:
- Press ALT+SpaceBar (simultaneously).
- Press the M key (for Move).
- Press any of the arrow keys.
If the dialog is open, but off-screen, the above will snap the Window to your cursor and you can then click somewhere on-screen to get it back on screen and usable.
Thank you for sharing the solution.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Pull down menus not showing up |
Tue, Aug 2, 2005 at 11:26:12 AM
Materials Bitmap Editor needs to be created |
Sun, Jan 29, 2006 at 4:25:45 PM
grant permit request doesn't pop up |
Tue, Aug 1, 2006 at 1:27:32 PM
NEED A POP DISPENSER |
Fri, Oct 20, 2006 at 10:15:40 AM
Revit 2014 SHEETMASS ZERO pop up issue |
Wed, Apr 30, 2014 at 2:55:50 PM
Members: | 2115251 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
