Forums >> Revit Building >> Technical Support >> steel pan visibility in 3D view ?
0 Posts No Rating |
Hello,
I use Revit 2016, it's a student version freely given by Autodesk so, if needed, I think could update to a upper version.
For my final review I am working on a project with a steel structure and with concrete + steel pan floor. I would like to make the steel pan appear in the 3D view (as in the picture I joined) but I don't understand how to do it, if it is possible. I would need it to make perspective anc section perspective.
I hope you can help me.
aybe I don't use the proper description (English is not my mother tongue), I found an old thread (2009) but it didn't really help.
Thank you
pastequevolante |
I would follow this procedure to make it look correct in sections, but I am unsure if it works in 3D.
https://forums.autodesk.com/t5/revit-structure-forum/metal-decking/td-p/4378874
If it doesn't, there are a few options:You could make an inplace family and just extrude the shape horizontally everywhere across your footprint and then use a void in plan to cut it to align with the building perimeter.
orYou could make a family of a single metal profile with length parameters and then just load it into your family and space them accordingly.
or
Your could make a family with a child family of the above mentioned description and use parameter arrays to allow a width parameter to also be added.
0 Posts No Rating |
Thank you.
I tried to re-make the floor but no success in 3D views.
I didn't try to make a family / child family, I am not enough skilled to do that.
I tried to modify a beam as suggested in the link you gave me but I am not familiar enough with Revit Families and it was a failure :/
I'll give up for now (no time to cath up my noob level on Families, I'll retry when I am graduated). I'll make them in Rhino and import them in Revit or vice versa.
Thank you for trying
pastequevolante |
I would do that with a model in place.
1 - create the basic extrusion in section.
2 - Extrude it to the maximum lenghts
3 - Array that to the full width of the floor - you will get a rectangle in plan
4 - Create voids to form subtract from the edges and inner voids as required.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Modifying stairs to use custom steel stair pan |
Fri, May 16, 2008 at 1:01:01 AM
Steel pan Decking |
Wed, Feb 4, 2009 at 1:11:28 PM
pan views |
Fri, Jun 25, 2004 at 3:56:51 PM
True plan view of sloped steel? |
Mon, Feb 27, 2017 at 9:31:23 AM
14
Anyone got a good (cheap or free would be nice too) pan software for............ |
Wed, Aug 16, 2006 at 8:09:08 AM
Members: | 2114828 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
