62 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Properties Palette
0 Posts No Rating |
Hello,
A co-worker was working on a project, and for some reason, the "Phasing" portion of the properties palette disappeared. Another co-worker was in the same project, but they could use the "Phasing" portion of the properties palette. Does anyone have any idea why this would happen? I literally have no idea why that would happen.
Thanks,
Colin
They both can't use the phasing on the same element or view at the same time.
0 Posts No Rating |
That isn't the issue. The issue is that one of them has the option to change the phasing, and the other one literally has no option to change the Phasing. In the Properties Palette, where there is typically the Phasing section towards the bottom, the one person literally doesn't have the Phasing portion on their Properties Palette.
You need to tell us more.
Is the person working in the same file?
Is this possibly a dependent view?
Is the view controlled by a view template? <<<< Look there.
Missing Orientation option (Project North/True North) in Properties Palette |
Fri, Jan 29, 2016 at 11:23:52 AM
create a legend for my finish palette? |
Thu, Jul 23, 2009 at 6:23:49 PM
Hide Instance Parameter ruled by formulas from the Property Palette |
Thu, Nov 21, 2019 at 11:26:43 AM
put object ID field in the properties palette in the family editor |
Mon, Oct 17, 2011 at 12:02:32 PM
Changing the Material [...] in Edit Assembly isn't bringing up Materials Palette |
Fri, Mar 28, 2014 at 4:12:50 PM
Members: | 2058118 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
