63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Export Links as External References Greyed Out
Tue, May 16, 2017 at 11:32:44 PM | Export Links as External References Greyed Out
RockFish
5 Stars: 2 Votes
I just opened Revit 2018 to do a quick little project. Did the work, purged everything from my project (including sheet boarders and went to export a sheet (without a boarder) as a .dwg. When I go through the steps to export the .dwg the option to not export all views as external links is locked. Meaning the "Export views on sheets and links as external references" box is checked and greyed out so I can't uncheck it.
I didn't think it was the cause of the problem, but just to be sure, I loaded a sheet frame/boarder back into the project. Still no luck on not having every drawing on the sheet created as it's own file.
Any help or thoughts would be greatly appreciated. Not a great start to Revit 2018. >Sad
Tue, May 16, 2017 at 11:38:42 PM | Export Links as External References Greyed Out
RockFish
5 Stars: 2 Votes
Maybe I answered my own question. On the previous screen I changed Export: <current views/sheets only> to <in-session views/sheet set> and the option to not export a views as external references on the next page now becomes available to uncheck.
Not really sure why or how this affects this option. What the F is in-session anyways...the project, the file, the time I work in the file between 8 and 5.?
Wed, May 17, 2017 at 4:05:36 AM | Export Links as External References Greyed Out
archigrafix
5 Stars: 4 Votes
Try to save the DWG export configuration to a new name, load it, and change the settings.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Wed, May 17, 2017 at 8:24:07 AM | Export Links as External References Greyed Out
RockFish
5 Stars: 2 Votes
Hmmm, that appeard to work... Is this a glitch in the software or is it intentional that it works this way?
Export Revit Sheets to AutoCAD Sheets with External References?
Mon, Nov 21, 2011 at 11:48:10 PM
How to include links in a GBXML export
Thu, Sep 25, 2008 at 9:35:01 AM
Export from Revit To CAD with RELATIVE linked files
Wed, Nov 29, 2017 at 11:00:36 AM
Revit Links not included in file export
Tue, Mar 1, 2011 at 9:33:46 AM
Export to DWG format as a polyline
Tue, Jan 27, 2009 at 11:27:27 AM
Page generation time: 0.3749
