43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Titleblock Key plan Parameters
Thu, May 11, 2017 at 11:21:40 AM | Titleblock Key plan Parameters
jeeenyuss
Hello,
I have a question regarding keyplans for titleblocks.  In order to thoroughly ask my question, I need to provide a little bit of background.  I am working on a project for a client who uses a very extensive sheet naming structure.
Sheets are named starting with the Project Number <red>, then followed by Site Name <blue>, Building Number <green>, Floor Number <orange>, the building's Wing <magenta>, Discipline, Type, and finally the Number <cyan>.  I have created parameters in order to populate the titleblock with this information.
I have used instance parameters in order to highlight the location of the associated work in the keyplan for use on each sheet.
My question is this:  Is there a way to create either a parameter or formula which will automatically highlight the appropriate area of work in the keyplan, which will do so based on the Wing <magenta> parameter?
This would be incredibly helpful for this project, as well as multiple other projects, because we do lots of work with this client.
Any information will be helpful.  Thank you very much in advance.
-Colin
Mon, May 15, 2017 at 11:31:19 AM | Titleblock Key plan Parameters
ryanehly
3 Stars: 2 Votes
Edited on: Mon, May 15, 2017 at 4:28:14 PM
Mon, May 15, 2017 at 2:42:17 PM | Titleblock Key plan Parameters
3.5 Stars: 395 Votes
I'm not sure that the previous poster wanted to sound blunt but I think he was suggesting the K I S S principle.  That is typically good advice in a lot of situations.  In this case, multiple legend types with the various areas highlighted as appropriate would be a simple and far easier solution.   No need for anything automatic since the user placing the view on the sheet would know what type key plan to place and that would never change.
BTW - The previous poster is NOT a moderator.
Edited on: Mon, May 15, 2017 at 2:44:23 PM
Mon, May 15, 2017 at 5:02:02 PM | Titleblock Key plan Parameters
archigrafix
5 Stars: 4 Votes
Maybe it that can be done automatic or semi-automatic. If the building number is a shared parameter, maybe it then it can be pushed into another field  with IF conditions to evaluate the right graphics to turn on.
You may need a schedule to make it work (semi-automatic).
It would be nice to hear if you succeed.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Instance Parameters in titleblock not linking
Wed, Dec 28, 2011 at 10:31:23 AM
12
Multiple blocks key plan
Thu, Aug 30, 2018 at 6:53:46 AM
Titleblock Parameters [ 1 2 ]
Thu, Mar 13, 2014 at 4:57:53 PM
17
How to link shared family parameters into an assembly titleblock?
Mon, Apr 20, 2015 at 8:14:15 AM
Key Schedules and Shared Parameters
Tue, Oct 7, 2008 at 3:14:43 PM
Page generation time: 1.0001
