68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sloped floor divided into parts - R2015. R2016
Mon, May 1, 2017 at 5:58:44 PM | Sloped floor divided into parts - R2015. R2016
iamian33
iamian33 Avatar
Greetings.
I am trying to create a sloped floor slab using Split Lines and Modify Sub Elements, then use Parts to identify multiple finishes.  Does Revit allow this?
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Tue, May 2, 2017 at 9:27:21 AM | Sloped floor divided into parts - R2015. R2016
Split line and split face are two different tools.
Split line: allows you to add linear edges and to split the existing face of a floor into smaller sub-regions.  Then with a variable thickness layer, the top face of the roof or floor can slope, and the bottom stays in a horizontal plane, creating a variable thickness floor.
Split face: allows you to modify the face material of elements.
Tue, May 2, 2017 at 10:29:34 AM | Sloped floor divided into parts - R2015. R2016
iamian33
iamian33 Avatar
WW
I appreciate your response and the definitions, but perhaps you missed my question.
Can I use parts to define multiple materials on a floor slab and still have the functionality to warp the slab using modify subelements (i.e. split line and add point)?
I am finding that once I've modified the subelements, I no longer have the option to create parts - if I create parts 1st, then I cannot access the modify subelements.  Perhaps this is a limitation of Revit 2016 ...
Ian Shafer
Tue, May 2, 2017 at 1:25:08 PM | Sloped floor divided into parts - R2015. R2016
I don't think you understand FLAT.   Read this.
Wed, May 3, 2017 at 3:48:10 PM | Sloped floor divided into parts - R2015. R2016
sllana
5 Stars: 2 Votes
yOU HAVE THE ANSWER IN YOUR QUESTION: YOU CAN NOT DO BOTH THINGS
Thu, May 11, 2017 at 4:43:53 PM | Sloped floor divided into parts - R2015. R2016
iamian33
iamian33 Avatar
Thank you both for your kind and supportive answers ...
Ian Shafer
Dividing an external wall into different parts per floor
Fri, May 12, 2017 at 3:46:58 PM
Sloped floor
Thu, May 29, 2008 at 5:22:08 PM
add ins go to r2014 and wont load to r2015
Fri, May 2, 2014 at 2:38:48 PM
Revit 2012 - Parts won't divide
Tue, Mar 18, 2014 at 3:37:44 PM
Sloped railing on sloped floor/ramp
Tue, Dec 9, 2008 at 9:25:01 PM
Page generation time: 0.9797
