105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Room Area & Volume Computations
Fri, Apr 21, 2017 at 8:35:36 AM | Room Area & Volume Computations
stuckinsky
Hi,
My firm typically calculates room areas / boundaries via the Centerline of the walls separating units, and exterior face of Exterior walls. IE: We calculate suite areas with two separate area computations. Revit only allows to choose wall center or core layers. My question:
How can we calculate room areas with both exterior face and centerline?
Fri, Apr 21, 2017 at 1:39:08 PM | Room Area & Volume Computations
Use room boundry lines.
Room Area to Exterior Face?
Fri, Jun 27, 2008 at 11:37:51 AM
Room computations failed. Try to modify the following elements.
Mon, Sep 9, 2013 at 7:41:11 AM
How do you stop the volume from extending through the light fixture?
Tue, Sep 23, 2008 at 2:16:41 PM
Room areas in windows schedules
Fri, Sep 19, 2008 at 2:18:23 PM
Room Volume "Not Computed"
Wed, Sep 19, 2012 at 12:46:27 PM
Page generation time: 1.0734
