73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> importing sketch up models
Tue, May 23, 2006 at 4:46:51 PM | importing sketch up models
bigstein
Hi Has anyone had success importing sketch-up models into Revit 9? What is the procedure please? Thanks
Tue, May 23, 2006 at 5:21:17 PM | RE: importing sketch up models
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Depends how you want to use it... If you want to use it as a base to create your model in revit then best to import it into to revit. Note it will not import if you've added too much detail in sketchup. For using a mass revit is only expecting a mass like form from sketch up. If you just want to show it you can import it straight into revit rather than in a mass. HTH.
Wed, May 24, 2006 at 11:51:45 AM | RE: importing sketch up models
bigstein
Do I need to save my sketch up file a certain way? When you say mass, do i need to convert the sketch up file into 1 component to bring it in? What is an IFC file? Thanks for tolerating my questions...
Wed, May 24, 2006 at 10:07:00 PM | RE: importing sketch up models
puzzle
4 Stars: 10 Votes
You can import your sketchup as mass. Go to a 3d view Create mass<give it a name File<Import cad formats<file type Import. I have only been shown this once so it may not be completely correct. Good luck.
Macca
Sunshine Coast
QLD Australia
Thu, May 25, 2006 at 8:24:09 PM | RE:
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Shouldn't need to save your sketch up file any specific way. Mass is a revit term, as outlined by puzzle.
IFC stands for industry foundation classes and is set to be the method of choice for sharing BIM models, however still needs a lot of ironing out.
Post edited on 2006-05-25 20:24:35
Fri, May 26, 2006 at 8:48:55 AM | RE: importing sketch up models
bigstein
Hi Ok - thanks for helping me import my sketch up model. Now that it is in there, do I need to expode it in order to assign levels and edit, cut sections, etc.? Thanks
Tue, Aug 22, 2006 at 10:11:08 AM | RE:
dashgarnett
Hi
Thanks
Does anyone know if the sketchup model brings in the materials...or ifyou can force it to in some smart and clever way?
thx
Thu, Aug 16, 2007 at 2:49:19 PM | importing sketch up models
JHanby
3.5 Stars: 3 Votes
I have tried several time to import a sketch up model into revit 9.1.  I keep getting a fatal error and crashing.  I tried puzzle's advise with the same results.  What's the trick?
Thu, Aug 16, 2007 at 2:52:11 PM | importing sketch up models
broncos4life
3.5 Stars: 11 Votes
You need to back save sketchup to Sketchup 5 not 6.  Sketchup 6 makes 9.1 crash, this issue is resulved in RAC 2008.
Thu, Aug 16, 2007 at 3:08:24 PM | importing sketch up models
JHanby
3.5 Stars: 3 Votes
Thanks! Didn't know that.  Worked great.
importing sketch up files
Thu, Apr 7, 2011 at 4:12:05 AM
Help - Sketch Up Models are hidden!?
Tue, Dec 7, 2010 at 10:35:47 AM
Importing OnyxPalm models into Revit
Mon, Aug 29, 2005 at 11:47:58 PM
Importing Tekla Structural Models
Wed, Nov 24, 2010 at 7:11:17 AM
Revit into Sketch-up?
Wed, Feb 17, 2010 at 1:08:27 PM
Page generation time: 0.7834
