77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Joining Walls_Floors_Columns
Fri, Mar 31, 2017 at 1:16:20 AM | Joining Walls_Floors_Columns
Reddrev
Hi,
Revit 2017
For some reason my insitu concrete walls, floors, and columns are not automatically joining.  They all have the same material attributes.
The design is a hi rise apartment block, using structural sheer walls.  To manually join every element will take a very long time.
Is there other criteria I might be missing to make the autojoin work ?
Many thanks.
Fri, Mar 31, 2017 at 10:32:41 AM | Joining Walls_Floors_Columns
I doubt your walls and floors are poured at the same time.  That being said, if you edit the floor sketch and the walls/floors intersect, Revit will give you the option of cutting the floor intersection out of the wall.
Roof Joining Issue
Mon, Jan 21, 2013 at 7:54:19 PM
12
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:10 PM
BEAMS JOINING COLUMNS problem
Tue, Jun 30, 2015 at 7:41:52 AM
Roof Join with Joining roof slope cutback
Tue, Jun 26, 2012 at 6:29:26 PM
roofs - extra geometry after joining
Thu, Jun 25, 2015 at 10:56:04 PM
Page generation time: 0.7117
