Forums >> Revit Systems >> Technical Support >> Handrail - Wall mounted
Hello, I have a Railing system just with the handrail (no ballusters o posts). I have seem examples where they easily change the type of handrail to "pipe - wall mounted" and the brackets show up but I don't have that option. I downloaded a wall mounted bracket but I can't seem to incorporate it to my existing handrail. any suggestion? or how could i add a type parameter for the brackets to a handrail? if you know an easier way to resolve this I 'm open to suggestions. Thank you!!
Hope that this old one can help.
https://www.revitcity.com/forums.php?action=viewthread&thread_id=22344
There are two files, Stair-and-Railing 1 only has the middle handrail and #2 is empty
Just as I said in that thread. The second file has all required families in it. Go to families, load all railing families into the project, then you can build all railings.
use these, baluster and settings, guess you u have to convert to imperial; and give it a try
No top rail but rail1 40mm = 1.57" diam. at 3' height
handrail, wall mounted |
Fri, Feb 13, 2009 at 1:47:37 PM
Stair handrail - wall mounted |
Thu, Jul 7, 2016 at 3:25:12 PM
Glass Balustrade with side mounted handrail |
Mon, Nov 18, 2013 at 11:31:01 PM
wall mounted handrail |
Thu, Jul 7, 2011 at 6:54:06 AM
Rvt 2013 Handrails for 3-run stair |
Tue, Aug 6, 2013 at 12:03:29 PM
Members: | 2116454 | Objects: | 23196 | Forum Posts: | 152303 | Job Listings: | 3 |
